Brief Description: Auto pilot pitch servo bracket - GSA 28
I mounted and drilled the bracket for the GSA28 to control the pitch of the aircraft. This included removing some material from the bulkhead to allow the bracket ot lay flat alongside the floor ribs. I then marked and drilled the bracket, cleaned it and tossed it into the primer bin.
One note the aft most hole for the bracket had to be moved inboard slightly more than the others to have proper edge distance for floor rib.
I also riveted the 4 top rivets on the floor rib brace, the side rivets will need assistance to rivet.
