Following the instructions I started installing the bolts on the gear tower weldments. I found a conflict between the hardware and the flange of one of the weldments. I had to stop and assess how to deal with it. Options, remove material, user thin nut. The thin nut would stil require material to be removed or place a washer under the head of the bolt to pull it away from the weldment.
