Before the flaps can be hung the aileron needs to be put in it's nuetral trailing postiion. I used a laser line across the tooling holes to align the trailing tip of the aileron, locked it in place with a piece of angle while I adjusted the bell crank and push tubes. Once aligned I then clamped the pushtubes in place and used some duct tap between the wng skins and the aileron to maintain alignment
