Brief Description: Flap drilling of ribs to lower skin and rear "spar
I used a variety of clamps to hold the parts in place per the instructions. I only needed to shim one of the ribs, the others all fit well. Once fitted I then drilled all the existing holes and layed out and drilled the 6th hole closest to the rear spar of the flaps.
