Brief Description: Drilled the holes for conduit, Pitot, and AOA
I made the final decision that I am going to have my communication antennas on the fuselage. This means that I don't need to run Coax, leaving me with a single run of conduit from root to tip in each wing and the right wing also gets a hole for the AOA and Pitot lines.
I created a template and drilled the holes in all the ribs. When completed I deburred all the holes, the ribs are ready for priming once I figure out how to mark them(they are marked now in sharpie, that will come off when I clean with MEK before priming.
I have the safe-air pitot/AOA kit and I am using 1/2in pvc tubing(made for sprinklers) rather than the corrugated stuff from Vans.
