Brief Description: reprime counter weight and dimpled skin
After earlier counter sinking the counter weight I reprimed to cover the areas exposed from the process. I blind riveted the end ribs to the aileron counter weight (formerly known as the water pipe). This involved bending the rib to accommodate the pop rivet tool. I then riveted those pieces to the aileron spar. Fitted the skins and used my 2x gun with a mail dimple die to dimple the skin to the counter weight.
