Brief Description: Cut hole for Duckworks light kit on the right side
I decided to the add a second light, this time in the right leading edge to match the left leading edge. I at first was not going to do this, but after looking at my common(future) mission profiles and the safety factor of a wing wag I opted to add this now.
I placed the order for the parts and used the template from the left side(reverse) to cut the hole and mark the ribs for the nut plates.
I then disaassmbled the parts and started dimpling. I was able to dimple the outer ring of rivet holes on the skin as well as the ribs.
