Brief Description: Assembled right side leading edge with replacement
Some of my ribs accidentaly got double drilled on on the top side leading edge hole. Instead of repairing/patching I decided to replace the ribs.
I started by straightening the ribs, then reaming the holes in the ribs with the a #40 for the skins and a #40 for the spar. I then clecoed the skin to the inderside of the ribs, placed the whole assembly on the spar and used tied down straps to to pull the skin down snug to cleco the top side on. I then math drilled the neccesary holes on eah rib and removed the leading edge to my work bench for cutting out the hole for the duckworks light kit.
