when I previously assembled the left tank I tried to place the AN833-6D in the right tank end rib, however i didn't use a deep socket and damaged the maiting surface of the AN833-6D. I finally got a replacement part and installed that. I started by placing the fitting in the hole at the noseof the rib, I pulled it out a 1/4 inch and packed sealnt around it, I then pushed it into the hole firmly, applied some sealant around the fitting on the inside and placed the AN924-6D nut on the fitting loosly. I then screwed the flop tube onto the fitting to make sure alignment was good between the fitting, flop tube, and anti rotation bracket. Once verified I tightned the AN nut down to 55inLbs of torque and covered it in a layer of sealant.
