Working on the theory that if I can just do a little bit every day...
I had one last task that needed to be completed before I can install the end ribs on the tank. I needed to safety wire my flop tube fitting per detail C on DW16A.
I started by torquing the B nut to 55 in-lbs, next I secured the safety wire. This took me three attempts the first was to long, the second I twisted the wire too far, and on the third try I got it right.
The can in the back ground is the proseal/flamemaster, it's fresh from the freezer. I'm letting it sit out on my work bench over night to thaw for my working session for tomorrow.
