I created the fuel trap doors using some of the hinge material that i had previously miss drilled for the elevator. No need to waste good material on this non structural component, esp since there were just a couple of oddly spaced holes.
Other than not riveting the 3rd hole that happened to align with the stamped ring in the rib it was easy work.
