AARON'S WEB SITE
Date:  3-25-2013
Number of Hours:  1.00
Brief Description:  Bolted Z brackets to the spar
I had an extra hour this evening and really wanted to get everything set to fit the tanks. I bolted the Z brackets to the spar, while this should have been quick it took a while both because of the tight spaces and the search through the bags to find the washers.
Once I had all the parts it was straight forward. There were some Z brackets that fit tightly and I needed to find the right order to tighten down the three bolts.
I'm not sure what I look so perplexed about...
