Brief Description: Drilled the leading edge of the left wing
In my effort to get the left wing to the level of the right wing(previous shop could only hold one wing at a time) I needed to install the rib closest to the tank, the tank bracket, and drill the leading edge. The fit and alignment of the rib and tank bracket was a little tedious but other than that it was a very straight forward process.
the clamp kept pieces from shifting while drilling
