I setup the jig for the fuel tank Z brackets today. In my first attempt to drill these at my old shop they ended up horribly miss aligned(I recylced them into the jig). After doing some research this is somewhat of a common issue. My plan is to center drill the middle hole and install the nut plate. Then I will place the piece on the wing solidly with hardware(something I didn't do previously) and drill the remaining holes.
