I have some parts on order before I proceed to the next step and was looking for something to work on. I have some finish work on the elevators still, but it was more than I wanted to tackle with the limited time I had. I remembered that I hadn't yet tapped the tie down brackets, after a quick trip for the right size tap it was an easy task. One was already mounted to the spar and the other I clamped to the work bench.
My advice is to go slow, keep it square,back out when you feel too much pressure, clean off the metal pieces, and make sure you dont cross thread as you repeat. That is what I was taught anyway...
