AARON'S WEB SITE
Date:  7-18-2012
Number of Hours:  0.50
Brief Description:  Built W-818 push rods
I built the W-818 push rods today. After reading more than a couple of posts on VAF I decided to buck these rather than squeeze. I had one whole that got a little bigger than it should have when the threaded component slipped while drilling, that hole got a AD470-12 the rest got AD470-11 rivets. It is not the nicest work I have done as the factory heads have smiles and the shop heads are wrapped around the curve of the tube but they are solid. My bench vise also nicked the paint on the tubes a bit so I ended up primering the entire assembly(except the threads) to make sure it doesn't rust.
I have noted them for special attention durring my next tech inspection.
