Brief Description: Finished the rigth side of the HS
I skinned the right side of the HS, and then riveted the end ribs(706, 404, 405) to the skin as well. The rear spar is not yet in place to leave it open for a tech inspection. The 702 rivets were all done by hand, the rib rivets were done with the pnuematic squeezer.
There were a few rivets that would not sit flush, I ended up using the dimple dies with the pop rivet gun and the vice grip dimple dies where I couldn't fit the pop rivet set. This pulled the dimples back into alignment and allowed the rivets to seat well.
I hope to get a tech inspection in the next week or two, in the mean time I will get started on the VS. I also need to figure out where I am going to store these pieces....
Looking like aircarft parts!
right side end rib(706)
The little LED light has been very handy for see the rivets as I drive them
