Got some of the HS parts out and pulled off the blue plastic. I am waiting for VS and Rudder parts to come (trim tab servo, conduit etc) so started deburring. Got HS-1007 HS-906 (1) HS-904 (1) HS-905 done. Went looking for other methods of deburring and came across a thread detailing cutting a 1" wheel into pie shapes, cutting a pie shape in half, then spooling it up on the dremel and running it on the 6" bench grinder to shape. This worked ok but they wear out rather quickly. You can make about 16 from a single 1" wheel 3m cut and polish wheel ($5.50 from Cleaveland) but not sure it is worth the effort.
