Tims Web Site
Date:  1-21-2018
Number of Hours:  5.38
Brief Description:  Start of the Rudder
Waiting for the replacment parts for the vertical stabilizer to come in so I started the the Rudder. Cut parts R-1004 A/B rudder root rib and R1003 A/B rudder tip rib apart and deburred. Cut R-1015 A-G L and R rudder stiffners apart and deburred. Deburred R-1005 rudder horn and match drilled to R-1004 A/B. Also cut and deburred R-1010 A-G stiffner shear clips. Process for parts: 1. cut with band saw or fiber wheel on dremel tool if it wont fit in the bandsaw. 2. rough sand with 36 grit paper on the 1" belt sander. 2. Grind edges of parts with Scotch Brite 7A cut and polish wheel on 6" bench grinder. 4. Grind top and bottome edge with 3m EXL wheel on 6" bench grinder. 5. Hit untouched corners of parts with 220 grit sand paper. 6. Run red Scotch Brite over edges of parts and cornes. May also use the blue 2" die grinder Scotch Brite pad to hit any scratches on the parts.
