Brief Description: Deburred skins and match drilled
Deburred R-1001 L/R skins. Clecoed one skin and R-1006 trailing edge into place on the skeleton. Marked the TE length, removed, cut, and replaced. Then clecoed the other skin into place and match drilled each corresponding hole between the skeleton and the skins.
