PHILIP'S WEB SITE
Date:  12-19-2015
Brief Description:  More RW closing
So again this method worked well, I also used a towel in the wing bays just in case I dropped the Titanium bucking bar as not to dent the upper skin. I also ended up having to remove the conduit to access the rivets with the bucking bar. I am very pleased on how well the skins lined up from the leading edge to the main wing skins!
Working inboard out towards wing tip
Used a towel inside to be safe
Close up of skins fitting together
