Had to cut about an inch off the aft spar with a Dremel tool in order to fit the aileron mounting bracket. Also had to do some trimming to the bracket itself. Working to fit the flight controls on the right wing. Still waiting for my shippment from Aircraft Spruce with my new Dynon Pitot/AOA tube, extension boom and fuel tank vent tubing.
RW rear spar over hang. Was useful on the stand but has to go now!
Trimmed and cleaned up!
Test fitting nearly ready to drill, but will measure a couple more times!
