Brief Description: Match drilled the wing walk doubler skins!
Match drilled both wing walk areas with the doubler skins. 13" by 27.5" they were flush with the training edge and ended prior to the top row of holes that attach to the main spar. This allows the wing skin to lay flat without buldging from the additional thinkness against the main spar.
