Brief Description: Adjustments for the Elevator Travel!
Had to make some adjustments and trim the Horizontal Stab Skin to fit the Elevators for up and down travel. Also had to cut a notch into the aft horizontal stab spar for the down travel. Looking at ofther builders logs this is common as the manual says it may need to be done!
