I will have to do some reserch to see if this is a common issue or if I need to make some adjustments or modifications. I can certainly trim the skin without interfering with the structure or any rivets. I just don't want to trim prematurely so I will look at some other builders and make a call to Paul.
Alignment good but.....
Small overlap in the forwad end of the elevators and the skin of the horizontal stab!
