Brief Description: Test fitting the Vertical Fin and the Elevators!
Test fit some of the other empennage components as I still need to cut the forward spar on the vertical stab and drill the three lower attach holes. Everything is lining up well...
Vertical Stab clamped in place!
Elevators attached for the first time!
Leading edge of all three points to the main fusealage!
