PHILIP'S WEB SITE
Date:  3-30-2016
Number of Hours:  1.50
Brief Description:  Horizontal Stab Drilling front support!
Measured and re-measured probaly 8 times! Talk about stressful and time consuming! I leveled the fuse and then leveled the stab as well as measured from the firewall to the leading outboard edge on each side. Both are 151.25 Inches! Had to make shims to level the horizontal stab. Drilled pilot holes and will remove to finish drilling them square!
Drilled Horizontal Stab Right Side!
Left Side!
Left Side!
Captured both Longerons and the Cross brace underneath!
