Brief Description: Paint Prep, Set Nose gear friction
Completed removing nose gear fairing. Set Nose gear steering friction to 26 lbs. per dwg. Drilled nose gear and installed cotter pin Tried anotherVans Dynon update number 6 try, Still will not work. Called Dynon and found that there is a revision to the download coming tomorrow Maybe it will work
