Brief Description: removed rear windoww to fix brocken screw
Removed nuts and washers from inside of rear window. Rmoved all machine screws and emoved rear window. Had to freill out broken screw and retap 6-32 hole. Chaed threds in other tapped holes. Opened window mounting holed in window skins. Reinstalled rear window using clecos. Will use machine screws lateer
