Brief Description: Reinstalled floor panels. First full power runup
Reinstalled all floor panels. Checked elevator cable tension. It is a little high will readjust. Moved a number of things around in the hangar and pulled the plane out onto the parking lot. Did a runup including full power (almost) it started to slide around. Found what appears to be a defective oil pressure sender. It is very intermittant ad reads too high.
