Brief Description: Set Prop Pitch, Installed Engine block heater
Set Propeller pitch to 12.5 deg. at tips Installed Prop Spiner to check fit. Drained engine coolant. Spilled the rest when I removed the plug. Installed the Honda engine block heater. Installed the block heater harness Refilled the engine coolant.
