Brief Description: Disassembled engine components for update
Removed oil cooler. Removed intake manifold. Removed oil drain hose from below engine. Removed rear oil cooler mount bracket. Removed existing oil cooler lines and fittings. Plugged drain hole on valve cover with supplied plug. Removed oil drain hose fitting from oil tank. Found that the supplied fitting fix hardware did NOT fit, Reinstaled fitting in oil tanl. Ordered a cap from Aircraft spruce. Ordered 2 new elbows for the engine side or the oil cooler lines. Need to shorten or replace the braided oil cooler lines
