Brief Description: Prepped Airframe for avionics mounts
Riveted nut plates to shelf Drilled aux battery mounting holes Cut hole fpr USB connector and drilled mounting holes Drilled Control module mounting and vent holes Drilled Xponder attach holes in firewall Drilled EMS attach holes in firewall Riveted nut plates on panel support mounts Rivetes Panel supports and radio supports to shelf Drilled ADAHRS mounting bracket attach holes on top fuselage skin
