Today I riveted the fwd and aft outboard seat ribs to the rear spar attach bulkhead. I also tourqed the bolt/nuts as well,(knowing my luck I might need to loosen these later as the manual doesn't say to tighten these bolts, but I was there anyway, so....).
I then riveted the fwd outboard seat ribs to thier respective bottom skins, I messed a couple of these rivets up and had t replace them.
I riveted the F-805G-1 gussets to the F-805-L-1 and R-1 bulkheads, and while I wasd thee I riveted the gussets to their floor support bars too.
I dimple countersunk the nutplates for the F-860C-L-1and R-1 aft armrests, and riveted them to the armrests.I did the same for the F-806A-L-1 and R-1 fuselage bulkheads, riveting three nutplates to each.
