Brief Description: Dimpling and edge rolling parts.
Today I dimpled the #19 holes in the aft side skins that hold the rudder cable exit guide clamp.
I dimpled the cover plate attachment screw holes in both rear side skins as well as the #40 rivet holes for the same.
I dimpled the #19 screw holes for the #8 screws in the fwd side skins.
Lastly I rolled the aft edges on the fwd side skins, the mid side skins, the centre bottom skins and the aft bottom skin. I also rolled the bottom edge of the two aft side skins.
Now to finish dimpling and start putting the fuse back together again.
