I machine countersunk the #30 rivet holes that were common between the centre section and the fwd floor. I then trial fitted the F-883-1 fuel vavle bracket. I had to trim a small piece off of the outboard edge, I clamped it into position, and marked the position for the two outboard bolts to retain the bracket and drilled the holes to #19.
