Brief Description: Fwd fuselage structure and skins
Today I clecoed the two skins to the structure and drilled the 1/8th holes common in the armrests and the fwd and aft bulkheads, as well as the F-807 bulkhead. I also drilled the 1/8th holes common with the two bulkheads and the gussets each rivet to at their lower edges.
Next I plan on positioning the two pivot brackets for the rear rudder pedals, these bolt to teh lower rear angle of the landing gear boxes, and it is easier to work on them now than when the fwd section and mid fuselage sections are clecoed together.
