Today, I clecoed the two 806 bars, the two seat belt attach lugs and the gussets to the rear spar bulkhead and riveted them together. I riveted the front five nutplates to each seat rib angles. I riveted the fwd seat belt anchors to their respective inboard seat rib.
I riveted the seat rib angles to their inboard ribs, along with the 805 brackets. I left the forward most four holes in each seat angle open as these are riveted to the seat ramp supports later.
I then clecoed the 814 fwd inboard ribs, the 814 aft inboard ribs to the rear spar attach bulkhead.
I called it a day here
inboard fore and aft ribs clecoed to the spar attach.
