Rogers Web Site
Date: 7-22-2014
Number of Hours: 2.00
Manual Reference: 8-11/12
Brief Description: Rear center section/seat rib sub assembly.
Today I debured the newly drilled rivet holes in the floor supports, seat supports, the rear center section itself and the vertical bulkheads, I also edged all parts except the rear center section.
I then cleaned the floor/seat supports and the vertical bulkheads with MEK and left them to dry, which didn't take too long. I then primed those parts, leaving the rear center section alone as it is anodized. I set them aside to dry, I prefer the primer to dry over night before actually working on the primed parts.
So I decided to pull out the parts for the next part of the build, the seat rib sub assembly. I pulled out all the parts, and it took a long time to find the seat belt attach lugs 806G-1. I went through everything three times. parts that are in boxes have their part numbers on the box. I'd been through all the bags brown and clear three times and still couldn't find them arghhhh! so I went hrough everything again, this time emptying the brown bags and there they were hiding at he bottom of the bag. So I had all the parts out, and just for fun clecoed the 806 rear spat attach bars to the rear spar attach bulkhead I also clecoed the seat belt attach lugs and the gussets to the rear spar attach bulkhead.
Rear Center section agin prior to debur, edge etc/
Vertican bulkheads/seat/floor supports all primed and drying.
The seat rib sub assembly parts, some clecoed.
