Rogers Web Site
Date: 6-27-2014
Number of Hours: 3.50
Brief Description: Firewall and associated parts
Today, I edged all the parts that are being riveted to the firewall. While doing this, I managed to slice my thumb with the edging tool, as it was in the way, just as the tool came off of a piece of ali that I was edging. See the pic of the 'workshop band-aid' a piece of kitchen roll held on with masking tape, works every time.
I then, as per plans, riveted the nutplates to the centre cross piece, and one of the uprights (see pic). Then I rubbed down the side of the parts that would be in contact with the firewall and primed them with an etch primer.
I clecoed the parts to the firewall, ready for riveting. Starting with the 4-4 rivets first, I placed a rivet in every other hole, as I had clecos in the rest, and used masking tape to hold them in place.
After riveting about half of the 4-4 rivets, starting from the middle outwards on the cross pieces and the uprights, I started on the rivet line of the top cross piece. Only to mess up the first five of these, I think where I had moved my riveting plate to on my bench, allowed the plate to 'bounce', while riveting, or I missed the plate, so these need to be drilled out and done again. I decided to call it a day. I'll drill these out Monday and finish the riveting then. So far the new fan does a good job.
Thumb injury. Primed cross pieces in the background.
Platenuts on the cross piece and the upright.
Firewall with some of the riveting done. Clecoes are on the opposite side.
