Today I edged, debured and dimpled the leading edge nose ribs, the rear skin end ribs and the leading edge skin. I countersunk the counterweight, and riveted the stiffeneres to the rear skin.
I bent the rear skin to the correct shape.
I then riveted the nose ribs to the counterweight, and then clecoed the assembly to the spar. I clecoed the leading edge skin to the counterweight and spar and riveted the nose end ribs to the spar. I then clecoed the top edge of the rear skin to the spar, but under the leading edge skin. I've set it aside now for riveting
Aileron rear skin/stiffeners rivetd together.
Leading edge skin after dimpling.
Starboard aileron rear skin and leading edge ready to rivet to the top edge of the spar.
