Brief Description: Starboard wing skins/fuel sender hatches/405 tank
As it warmed up a bit today I did some work on the wings and fuel tanks. I first riveted the fuel pickup pipe locking retainers on both fuel sender hatches. I then riveted the 405 fuel tank mounting brackets to both tanks.
I mixed up some sealer and then sealed the rivets and the locking bracket edges on the fuel sender hatches. Then I sealed the 405 fuel tank mounting brackets and also sealed the 405 rivets on the inside and out.
I thought is would be a good idea to 'label' the rivet callouts on the right wing top skins to help stop confusion with rivet sizes, so I did that as well, writing the callout on the skin.
