Brief Description: Leading edge and fuel tank, left wing
I clecoed the tank skin, two outer ribs and two center ribs together and did the same to the leading edge. I then clecoed them both to the spar, the tank skin fitted fine at the corner mating with the leading edge at the spar, but, the skin elsewhere overlaped the leading edge skin, this can be seen in pictures 1 and 2
Tank skin overlap upper surface.
Tank skin overlap underside.
Tank skin and leading edge together, just for an idea of what it looks like.
