I took the leading edges off the spar and fabricated the W-423 supports for the outer fuel tank edges. I then dis-assembled the leading edges and removed the protective film from the insides and the rivet lines on the outsides. I found if I left the panels in the sun the film came off much easier, good ole Texas sunshine!
