I made the 706 for the right spar. Edged and beburred both brackets. I drilled the rivet holes for the 706's to both spars, also drilling the rib holes in the spar to the 706's, using a 'square' to make sure they were in the right postition on the spars. Deburred all new holes in the brackets and the spars. Primed the contact surfaces of the spars and brackets, and riveted the brackets to both of the spars. I put the right spar away for now. I then edged and deburred all of the parts making up the left spar. When that was complete I dimpled the frame and skins for the left flap and cleaned the parts and primed. All is ready for assembly now
Drilling the 706 rivet holes to the left flap spar, using the 706 as a template.
