Brief Description: Deburring, priming, and re-assembling the right wi
I took the right wing frame apart. Deburred all the drilled rivet holes. I primed all the ribs and primed the freshly holes in the front and rear spars on both sides. That used two rattle cans. I had raised my work table by 10 inches and it made working on it much easier on my back. Lynn helped me lift the wing frames on and off the workbench to make sure nothing got damaged.
