Rogers Web Site
Date:  3-5-2013
Number of Hours:  3.00
Brief Description:  Fitting elevators to the HS
I checked the rod end bearing measurement again, just to be sure. Pilot drilled the the WD 605 control brackets on both elevators, and very carefully drilled them to final size. Now came the really fiddly bit, getting the rod end bolts in, placing the washers and nuts on same. I used a small extendable magnet I have to put the bolts in, like I said fiddly, but got there in the end. The spacer washers on the centre bearing were awkward too, No real problems, just used up some time.
I'm going to hold off on the fibre glass for now, I plan to do that all in the final stages fo the build.
The HS/Elevators done.
My little magnet, made life easier
