Today, I fitted the aft deck along with F-810 bulkhead and F-810D spacer and drilled all the 1/8th holes common between the aft deck and the upper longerons as well as the 810 bulkhead and 810D spacer.
I marked the longerons for the notches that are needed for the F-811B stab attach bars, using the aft deck as a template, and I marked the aft face of the F-812 bulkhead on both longerons, because these will be trimmed later.
I clecoed the F-812B control stop to the aft deck, drilling the two outer holes to #12 and inserting temp bolts, and finished drilling the remaining middle three holes to #30.
I clecoed all the holes in the top sections of the F-802N bulkhead caps and placed the cockpit rails into position using the centre bulkheads to locate them, I still need to line the rails up with the outside edge of the mid fuse skins, I'll do that next.
