Rogers Web Site
Date:  12-23-2013
Brief Description:  Fuel tanks
I did some more work on my fuel tanks today and I sealed the outer ribs to both tanks. I used a cheap 1" brush from Lowes, (that's a B&Q type shop for my UK readers) that has had it's bristles cut down by half so it could be used as a stippling brush. I covered the ribs' edges with the sealer and then installed them into the tank skins and clecoed, I'll rivet them tomorrow.
I decided to install the innermost ribs even though I do not have my pipe flaring tool yet, but as the aluminium tube used for the breather is so soft that it could still be installed after the inner rib was riveted in place, I decided to go ahead.
Starboard tank innermost rib, with the tank sender unit
Starboard tank outmost rib
Mixed sealer with applicator brush
