I assembled furl sender untis to the inspection panel and measured, and cut the rods for the floats. the floats themselves actually face opposite directions because if the float for the right tank was facing forward, as the left sender is it impacted the stiffener. So I turned it around. After doing that I started clearing the excess sealer from the dimples in the right tank skin, so that the rivets should sit flush and look pretty.
